Lynnmor
Jul 10, 2016Explorer II
I think that the Stabilitrack is causing the problem. The wheel speed sensors may be not reading correctly and the system is applying the brakes on opposite sides. It needs to be serviced right away. Another test is to use a heat gun (available cheaply at Harbor Freight), and check for higher temperatures on the higher pressured tires. Heat increases pressure.
44,060 PostsLatest Activity: Mar 26, 2026
