demiles
Dec 22, 2018Explorer
Tire Pressures?
I’ve noticed that 1/2 ton trucks have the same recommended tire pressures front and rear while 3/4 ton and up always have a pressure offset front to rear. Why don’t they run a offset on 1/2 ton trucks...
KD4UPL wrote:
1/2 ton trucks tend to carry about the same weight on the front and rear axles when fully loaded. Look at the door sticker on the jamb and you will see the FAWR and RAWR are pretty close.
2500 and 3500 trucks are designed to carry a lot more weight in the bed so their RAWR is generally several thousand pounds higher than the FAWR, thus the tires need more air. The front of either truck generally weighs about the same no matter what since the cab, hood, engine, etc. are basically the same across 1500 to 3500.
