demiles
Dec 22, 2018Explorer
Tire Pressures?
I’ve noticed that 1/2 ton trucks have the same recommended tire pressures front and rear while 3/4 ton and up always have a pressure offset front to rear. Why don’t they run a offset on 1/2 ton trucks...
Artum Snowbird wrote:
I have caused undue wear on tires because I overinflated, and underinflated tires. The absolute best way to adjust pressure is by taking the truck ready to roll over a scale that scales each tire... or at least measures both fronts and both backs. Then look at the tire specs and see what pressure you need to carry the load you have.
