demiles
Dec 22, 2018Explorer
Tire Pressures?
I’ve noticed that 1/2 ton trucks have the same recommended tire pressures front and rear while 3/4 ton and up always have a pressure offset front to rear. Why don’t they run a offset on 1/2 ton trucks...
downtheroad wrote:
Our 4WD diesel recommends 80 psi front and 55 psi rear for full payload rating. Quite a difference. It's due to the weight of the heavy diesel motor and the front transfer case.
