cairopd1069 wrote:
Mine is a tandem axle and the tire was worn on the outside edge. The separating tread is a major concern as well. Just trying to get some ideas on why only one tire is doing this. Of course I'm checking the others as well. Thanks for the response.
I take it they are 'C' rated tires......50PSI max psi
Trailer tires get abused....curb hopping, potholes, twisting motion/lateral forces when maneuvering, etc
Belts separate.
Alignment, bent spindle, BAD tire
Replace and be glad YOU found it vs blow out & damage
