cairopd1069's avatar
cairopd1069
Tire problem
I have a 2015 Coachman TT and I "accidentally" found a problem with one of my tires. I will pay a lot more attention to them now. I always keep them at 50lbs and the TT is stored under a carport and shielded from the weather when not in use. I discovered the right rear tire had worn excessively on the outer edge. We were on a trip so I changed the tire. When rolling it to put it away, I noticed the tire was separating within the tread and had a "gouge" on the outside edge. The set of tires are the ones that were on the TT when I bought it and none of the other ones "appear" to have any flaws at this point. If the pics will post, I would appreciate any input on what might have caused this problem. Trail Express 205/75/r14
Thanks in advance.
  • Thanks for the reply. I will take it to an alignment shop tomorrow. I am considering replacing all of them, but finding a consensus as to what tires are best is a chore!!
  • I think I would replace all the tires.
    As for the one wearing excessively on one edge, I would think that the tire/wheel is at a slight angle (toe out?). I would have it inspected by some one in an alignment shop.
    Also, you have a Coachmen..not a Coachman.:D
