I just got new tires and they state inflate to 44 PSI. Why did the dealer only put 32 PSI in them? I believe that is what it says to do on the door but these are different tires than what came on th...
The information on the door post gives the proper pressure to enable handling the maximum load the vehicle can carry (GVWR) when using the OEM tires. The NEW tires are apparently in the same class (passenger car tires) so would inflate to the same pressure.
I would READ the part where the tires says what the inflation pressure should be because that makes no sense at all. Tires are NEVER advising what the proper pressure is, they only state what the MAXIMUM pressure they can handle is.
