I just got new tires and they state inflate to 44 PSI. Why did the dealer only put 32 PSI in them? I believe that is what it says to do on the door but these are different tires than what came on th...
Generally the door post is correct. If you scale your vehicle and know the weights of each wheel you can look up load index charts that most tire manufacturers have on their web sites. Example
