Correct me if I'm wrong, but aren't all tires of the same type (ST/LT) and the same size (225 75R15) and same load range (C,D,E) rated just the same (as to weight capacity) regardless of manufacturer?
For a given tire size and ply rating they are the same IF and ONLY if they have the exact same load INDEX. They have replaced the ply rating and size to determine load rating with a 2 or 3 digit number giving the load index. load index goes from around 70 to at least 150. For a given tire size and ply rating the load index can vary slightly. For instance, on my truck tires I've seen load index of 116 or 118 depending on specific tires.
