JimK-NY
Apr 17, 2017Explorer II
Tire Ratings
There is no doubt about it. Truck campers are heavy and most of us are probably close to the load capacity of our trucks. When it comes to load capacity, the limiting factor is often the tires. I k...
S Davis wrote:
One thing I would keep in mind if you at max on your tires/wheels, your load is not the same on both sides and even though you could be fine with the load on the rear axle one side could be carrying more weight than the other and be over. So if you are close it is a good idea to weigh each rear tire to see where you are.
