crcr
Jun 18, 2017Explorer
hellfirehydra wrote:
I believe the best ST tire offered right now are the Maxxis Radials. I haven't seen a single bad review on them yet and is what I will be purchasing next without a doubt. What is the speed rating on the tires you purchased?
With that said, if you are like me and plan on replacing tires well before they are worn out, I wouldn't worry too much about using the ones you already have.
Speed Rating is M. I just looked that up and the chart I found says an M speed rating = 81 mph. Wow, surprisingly high! I generally try to keep it under 65 mph when towing.
Thanks, I'll check out the Maxxis Radials.
44,061 PostsLatest Activity: Apr 09, 2026
