Reedga
Jun 18, 2017Explorer
I have a 2014 Eagle 266 RKS and had D 8 ply rated tires. The first tire blew out at 6000 miles. I removed all the D rated tires and installed E 10 ply rated tires. The load capacity went from 2200 lbs. per tire to 2840 lbs. per tire. Also the tire pressure went from 65 PSI to 80 Psi. The increased tire pressure creates less rolling resistance, les tire squirming from side winds( better stability) and my towing fuel mileage went up 1 mile a gallon. For the minor cost difference go with the E rated 10 ply tire.
G. Reed
G. Reed
44,061 PostsLatest Activity: Apr 09, 2026
