Licreek's avatar
Licreek
Tire recommendations for towing
Hello all, my name is Lee and this is my first post.
i am selling everything and going full time rv.I purchaced a truck.Its an 05 ford King Ranch 1 ton quad cab short bed with 6.0 power stroke diesel. It needs tires, so that is my questionj. this truck is tall and right now it has 305/55/20 tires. it looks good but the factory sticker calls for 275/65/20. We are buying a 27' prowler 5th wheel with single slide. Should i go back to factory size and what brand and rating tire should i look for? Thanks for any help and i look forward to asking for alot more help in the near future, thanks,Lee
  • That tire is the same diameter as my stock size 275/70R18. Unless you have a lift your truck wouldn't be any higher or probably even as high as my stock Ram. Trucks have gotten taller over the years. I did have to do an axle flip on my fifth wheel but now it sits level and tows great. As long as your load rating is sufficient and you can run the trailer level I wouldn't bother changing the tires.
    My favorite brands for truck tires are Cooper and Toyo, although I'm running a set of BFG AT/KO2s right now and I really like the way the perform and they look sharp too. The treadwear may not be the best but time will tell, and I got a great deal on them so I'm not too worried about it. Had I not found the deal I found I probably would have gone with a set of Cooper ST Maxx.
  • YES....
    For better towing go back to stock OEM size 'E' tire
    You have lots of options in 20"
    I ran Michelin LTX A/T2 when we were FT....at 60,000 miles would replace
    Towed heavy...great wear/traction
    Hopefully you got one of the 'trouble free' 6.0 engines.
    6.0 Power Stroke Problems and Info
    Best of luck......
    FTng was a awesome lifestyle .......we miss it :(
  • I am biased toward Michelin tires. I have never had anything but good luck with them. Moving on though, with the taller tires there are two things to look at. One is that, especially if the truck has a lift also, it will get the truck to sit taller in comparison the the ride height for the trailer. It is especially noticeable with a fifth wheel, possibly requiring the fifth wheel ride height to be raised slightly. I just changed to a newer truck that sits slightly taller and it has changed the way the tires on my trailer wear. The second item I see is that the taller tire will change your final drive ratio, but as your trailer probably isn't anywhere near your capacity the difference shouldn't be a big problem.
