MM49 wrote:
Lowsuv wrote:
Keep in mind that it is LowSuv's intention to help the civilians on this forum with their tire issues .
LowSuv includes in his posts the logical evidence that indicate that Maxxis is a provider of lower grade tires .
Other motorheads on his forum who have decades of experience upgrading their tires on their hotrods , sportscars , pickups , and other trailers have a good understanding of how a real upgrade in tires is possible for little expense at changeover time .
LowSuv does not enter into personal attacks on this forum .
Maxxis ST tires are most often supported on this forum by references , such as " I really like them " , or " my tire guy ( whoever that is ) says you cannot use LT tires on a trailer ".
My whole intention is to allow other RV forum members to make a real upgrade that will eliminate / mitigate future ST tire failures going forward .
The evidence supports the position that Maxxis tires are not a better brand than other ST tires .
Those suggestions that just replacing OEM tires with a maxxis tire of the same load weight rating are just plain wrong . There is no gain to be made by that Maxxis replacement .
LowSuv repeatedly gives reasons why for 15 inch tires the 225/70R15 load range D Goodyear Cargo G26 is the clear first choice .
LowSuv repeatedly gives reasons why for 14 inch tires the 205R14 Kumho 857 load range D is the clear first choice .
A search through " view posts " for LowSuv will show that his suggestions are supported by logical evidence and have been consistent for a long time .
As a motorhead LowSuv made his first tire upgrade in 1964 on his 1955 BelAir by going to 720x15 tires instead of the 670x15 tires that came stock .
LowSuv has been upgrading his tires ever since .
I encourage upgrading tires at replacement time .
Changing brands to Maxxis does not accomplish this .
It would help if LowSuv was honest. He keeps on recommending LT tires that are rated at lower weight ranges for equivalent sizes and tires that don't fit our rims or trailer wheel openings. The increased leverage of using LT tires that are not designed for trailer usage is potentially damaging to the trailers suspensions and frames. Lt Tires don't meet the performance standards of ST tires.
MM49
Just to be clear :
MM49 asserts that LowSuv is not being honest .
Out west we try to keep the conversation civil .
