FastEagle wrote:
legolas wrote:
bob213 wrote:
Keep in mind that Lowsuv never misses an opportunity to bad mouth Maxxis tires. He's correct when he recommends LT tires if your trailer can handle the larger size. If you are stuck in the 14" range, your best choices are Maxxis or Kumho 857. In a 15" tire you are again limited and Maxxis would be my first choice. in a 16" you have a wide range of LT tires that would serve you well.
I hate to get in to this....knowing the angst of it ......however, are there no 15" LT tires that can go on a TT?
Not often.
FE
Thank You Fast Eagle for that knowledgeable information .
That was helpful .
Another answer is Yes .
Try researching the Goodyear Cargo G26 load range D tire .
3 sizes including the aforementioned 225/70R15 which fits everywhere that the ST 225/75R15 fits , without any modifications .
