Grit dog wrote:
Timmo! wrote:
I second the emotion---Goodyear Wrangler LT tires
This is not sound advice unless the OP's trailer has 16" or larger wheels, which it most likely doesn't, since it's a TT.
Available ST tires far exceed the capacity of 14" and 15" "LT" tires.
Whoooa Nelly...."not sound advice"? "far exceed capacity"? Let's not exaggerate. A tire that has 2.6% greater load capacity--isn't much of an increase in load capacity (period).
Granted I replaced GY Marathon ST205/75R15 (load range C for 1870 lbs) with GY Wrangler HT215/75R15 (load range D for 2095 lbs), providing me a tire with 225 lb greater load capacity. Now my friend, increasing a tire load capacity of 225 pounds (10.6%) is rather significant
About 4 years ago, ST Marathons were replaced with ST Endurance. So, let's compare those (even though Marathons are still being sold), GY Endurance ST205/75R15 has a load range D for 2150 lbs. I agree the Endurance tire has a greater load capacity of a mere 55 lbs than HT Wrangler, but that is only a 2.6% greater load capacity. Not very much and certainly does NOT "far exceed capacity".
The Endurance has a shallow tire tread depth of 8/32" (0.25"), while the Wrangler has a deeper tire tread of 14/32 (0.4375"), has a wider width and larger diameter, and higher speed rating.
At the time of my tire purchase, the HT Wranglers were only $5 more, and well worth the extra rubber.
Gotta look at the facts.
On edit--corrected math error 2095 - 1870 = 225 lbs, not 255 lbs. My bad.
