Bob_Landry
May 26, 2013Explorer
Tire Shine Compounds
After reading a couple of threads on this, my curiosity is up. Does anyone know of a comprehensive lists of tire shine products that are known to cause or not cause sidewall cracking?
Dick_B wrote:
I think this Forum gives 303 Protectant high marks.
travelnutz wrote:I asked the tire store I deal with about Ru-Glyde recently and nobody, including the store manager had ever heard of it. As you said, all tire stores used to use it when mounting tires, but I guess it is now history at least in Discount Tire store, as it is still available and the recommenced product by many sources.
Many years ago there was a product made called Ru-glide that was a non-petroleum non-silicone based rubber lubricant. Lots of hotrod dudes used it to make their tires shine and also as a lube to help mounting tire beads. Never used to see cracked tires using it.
X2. But I usually just clean em with soap and water and a brush.
DJF wrote:
I clean em with soap and water and if you want them to look pretty use Brake fluid, designed to enhance rubber.
You can thank Mr Smith my auto shop teacher from 1966.
