Cabman_850's avatar
Cabman_850
Tire size difference
Going to be getting new tires for a Ram 3500 that hauls a 3200lb hardside truck camper. The stock Firestone Transforce tire size is 275/70/18. I am going to be replacing these with Cooper AT3 tires and was wondering if I would notice a difference if I went with 295's since they are appx. 3/4" wider? The 295's are appx $50 more per tire plus I would need to order a spare if I changed sizes. Not sure it would be worth the extra $$.
  • The new tire size will be 20mm wider and 28mm taller than your current tire. Overall truck height will only increase by 14mm.
  • More important is does the capacity change. I wouldn't change the tire size, but there is probably minimal difference other than tire clearance.
