I had a 2015 Tradesman aisin with 4:10 and now a 2018 Larame with 3:73.
both with aisin only difference was the 2018 is 2wd.
The 3:73 does run around 500 RPM slower. TO be honest the 3:73 might help 1-2 mpg at highway speeds as we are moving a lot of air with the camper on. But even towing 7/14 box trailer without camper, I did not see that much MPG improvement over the 4:10. Now the 3:42 might be a little low for running highways with even just camper loaded, but worse case you might need to lockout 6th gear if the truck keeps shifting on hilly ground at highway speeds.
I think the 4:10 will have the advantage in the engine braking dept as I recall it would work all the way down to around 25mph.
But you said adding bigger tires: remember you need to get those tires between the truck camper jacks to load it (I live in central FL where I see these ridicules pickups with tires sticking 6" out past the fender edges).
I would picture bigger means taller tires, go with the 4:10. taller tires affect the gear ratio and the 3:42 may be too low.
But between the tradesman and Laramie, I would go with Laramie. I have the bucket seat option and I love those electric adjustable, cooled leather seats :) The other options are also great.
I think they will both hold trade value, but Laramie will have better trade value (but it cost more up front)
