TRAILRIDER125's avatar
Jun 22, 2016
Tire Valve Stem Extenders
I have a dual wheel truck and will be putting extenders on the tire valve stems. I can't check the air or add air to the inside rear wheels now unless I remove the outside wheels.
Even the outside wheels are difficult to work on. Do most of you use the extenders? Do you use metal or rubber stems? My valve stems are metal currently. Any advice?
  • What is needed is a extended valve stem that will let you quickly check your tire pressure. Extenders have a very bad habit of leaking.
    The best on the market,that are the original,are Tire Man.
    Chuck is the original designer of these an he has been around for years. If you have any questions just give him a call, he is always happy to help.
    The kit looks like This it is for all 6 wheels,they also come with flow-thru valve caps so you don't even need to take then off to check the pressure.
    Here is a list of all the products he sells.
