routeforty
Jan 09, 2019Explorer
Similar issue with my pontoon trailer. Tires were wearing on the outside, axle looked like someone smiling(bowed the wrong way). Went to local trailer shop and had a 3500lb axle put on in place of the 2500. Problem solved. Cost was $285 out the door.(axle, u=bolts, plate, & labor). This was summer of 2017. True, you will need a heavier one than 3500lbs, possibly a little more $$$. Labor in your area probably higher than here in amish country in Ohio. But if you decide to go the axle replacement route and could drag it to Ohio, I would give you the number of the shop, maybe they could give you an estimate over the phone. Gary
44,070 PostsLatest Activity: Jul 22, 2026
