tinner12002
Dec 18, 2014Explorer
tire wear
Just courious as to the tire wear some of you are getting on the rear of your dually...not mileage so much as wear from each tire, inside vs outside. I noticed the other day that my outside duals are ...
Cummins12V98 wrote:
I have basically the same truck. You are aggressive when taking off from a start. I ease into starting and have perfect wear across all tires within 1/32".
I run 45psi solo and 60 towing with 4.5-5K pin. I always run 80 fonts. Michelin MS2's 35K and 1/3 worn.
