PDX_Zs
Mar 07, 2018Explorer
Straight up: ProComp tires are generally regarded as bottom of the barrel.
They are made by Cooper (which is not a bad brand) but 4Wheel Parts has a pretty low spec for their rubber.
If you must have that size, check of these BFG A/T's
LT 285/65R20 127/124S E BSW 34.5" 11.5" 8-10" 8.5" 15/32" E 3860/3525 lbs 80 psi 60.3 lbs 60
From BFG's spec chart. I know it didn't come over well, but you get the idea. Rated higher than your current rubber.
Sure it will cost you more, but there is definitely a reason.
