colliehauler
Mar 07, 2018Explorer III
Artum Snowbird wrote:Have to agree with this, the last thing I would want is less stability while towing.
OK, lets look at this honestly. You have a trailer with dual bunks at the back, so there must be some little ones involved. You will likely be filling the back of the truck with bikes and other things. You can usually plan on being half full of water, either from gray and black or fresh.
So, the trailer is going to be carrying a lot of weight for all those people, the truck is too. The last thing you should do with a heavily loaded rig is raise it, and put on less weight carrying capacity tires.
Yes, you need to worry a lot. Get stronger with add on stuff, not weaker and taller.
