rsmith159
Dec 09, 2013Explorer
Tires again
Hi everybody. I want to replace the tires on a 2008 trailer I just purchased. I have a chance to get four new tires already mounted on beautiful seven spoke aliminum wheels. The tires are branded as H...
CKNSLS wrote:JJBIRISH wrote:
First of all there are a few obvious Maxxis detractors that make sure to post to every trailer tire thread
They have never offered a reason for their dislike of Maxxis other than they weren’t their choice and that somehow diminishes the good results so many others have had with them…
They offer unavailable testing of totally different type of tires that were tested against tires in the high speed category for sports cars as proof… the results if these test have absolutely no bearing on the quality of trailer tires period or on any other type of LT tire... it is unrelated, un meaningful words used to muddy the waters in these discussions ONLY…
They mention 19 failures of Maxxis tires as proof of bad quality, but make no mention that many if not most or even if any of the failures mentioned those failures, were caused by age, road damage, or run with low air pressure… again it is just too muddy the water and to provide cover their unproven opinions…
One points to and recommends the new Carlisle as the greatest thing since the wheel… while I hope he is right they are new and have no track record to stand on at all… if they are so good, I have to wonder why Carlisle the tire company sold them out to another company before their track record began to look like it old track record did… so now with the new owners that clock has to start anew and his cross-country trips were made on the now old new Carlisle tire…
The person that made the comment,
“Are Maxxis are cheap Taiwanese******with a Chinese plant as opposed to cheap Chinese******straight up?”
only proves his lack of knowledge of geography and where the tire is made to begin with…
Maxxix8008 is made totally made by Maxxis in Thailand… the pass was earned by being the only trailer tire company to build the tire to a higher standard and not cave to the OEM industries pressure to build the cheapest tire possible, and why they are not often found on new trailers…
The true facts are they isn’t a single person here that can point to comparative testing on trailer tires because it has never been done…
There isn’t a single person here that knows the failure rate, or the rate for types of failures of trailer tires, and that includes people in the tire industry… these test haven’t been done and the normal method of keeping track of returned warrant tires for other tires types are flawed and wouldn’t work for ST tires…
Lacking testing an information from the industry all we really have to go by are others experience, and this is how Maxxis has earned a good and growing better reputation… anyone that says otherwise is reading different forums or only reading what they want to into their assessments…
And as I believe intentional misleading to bolster a false claim is equivalent to lying and yes there are some liars that continually post on this…
You have no idea what has caused the majority of Maxxis failures. Just like those who bash other brands of ST tires have no idea what caused those failures. In addition, Maxxis has such a limited distribution system, for whatever reasons-please elaborate on how they will grow their brand. If Maxxis is indeed building to a "higher standard" whatever that means, then maybe they should build tires like everyone else because they certainly are not proving to being more reliable than any other ST tires. A 3 inch nail will take out an ST tire regardless of how much it weighs....period.
There are plenty of half truths floating around this board...including statements in your own posts.
