On page 2 LOWSUV said :
" The single best action when replacing tires is to increase your load weight ratings as posted on the sidewall of all ST tires .
If your weight rating on your current tires is 1820 # there are several options to get a 2271 # weight rating in 14 inch and 15 inch tires .
Your tire budget is better served by upgrading the Tires first and the wheels second .
TTs are parked 90 % of the time .
Who cares if the wheels are flashy for 328 days a year under your carport ?
If the Tredit tires are an upgrade in weight rating then that might be a good deal .
If the same weight rating as your current tires then I would reconsider and spend the money for bigger ratings for that time I am driving across the desert in 115 degree heat . "
That seems like a rational answer to me because nobody so far has admitted to buying Tredit Bias Ply tires .
