egarant
Feb 20, 2016Nomad
Tires LT235/80R17
Hi All, I am looking for a new pair of shoes for my truck that hauls my truck camper 99% of the time. I currently have on the Michelin LTX M/S2's that were terrific on the highway, smooth and ...
Steve_in_29 wrote:egarant wrote:Steve_in_29 wrote:
OP, while I see you have already bought the next set of tires here is a suggestion for next time.
Something to keep in mind if you are constantly running at the 14K weight is that the nylon/kevlar/etc belts don't hold up as well to being constantly at max loads as the ALL steel (tread and sidewall) tires do. The nylon sidewalls squirm more and thus build up heat which is death to a tire. That is why tires spec'ed for motorhome use (where the vehicle is constantly near max load) while still load range E are of ALL steel construction.
I found this out when I was researching tires for my previous motorhome and was wondering why I couldn't use the cheaper nylon ply load range E tires available for pickups instead of the all steel ones that were called for. I talked to tire companies and even a tech editor at Motorhome Magazine on this.
I will tell you exactly what the sidewall make up of the tire is when I get them. I sincerely doubt nylon will be listed.
I'll tell you what, these tires are not cheap.....$233 per tire, the most expensive tire Discount Tire sells for my truck, more than the Michelins!
No need to take offense, I was simply passing on information I had learned. Unless the tire is ALL steel there is nylon/kevlar/etc in the sidewalls.
I wish I could only pay $233 for my tires, each of mine go for almost $400 a pop.
