Time to put a new set of tires on my 2007 GMC 2500HD. When I bought the used truck it came with 10 ply load range Ds on it. (LT 245 75 R16) I have to run these tires at 50 PSI or else when I am drivin...
If you get a highway comfort tire like the Michelin M/S2 in the LT265/75-16 E-rated size and run them around 45 psi when you are unloaded, you'll get a much more comfortable ride. If you do the shocks it will be better as well. A slightly larger tire has greater load capacity, and a bigger volume of air so it can run slightly lower pressures and have less harshness.
