Need-A-Vacation's avatar
Oct 11, 2016
'13- 2500HD Tire Shopping
I am planning on new tires within then next month or so, and have it narrowed down to a few possibilities. Truck is stock, no leveling kit, and t-bars are still at factory adjustment. I don't plan on going with a (much) larger than stock tire as we have a fairly heavy tt (~9200lbs loaded), so don't want to change the ratio to much.
We also travel to Northern Michigan and Northern Ontario (Soo area) to go snowmobiling. The cabin in Ont is in the bush, about an hour to get to once through Soo customs....
Stock 265/60/20 is a pain to find an AT tire in. Found a few, but wish there was more available choices!!!
The leading contenders are:
Cooper A/T3: Had a set for on our '10-1500 and loved them!!! Great tire in all conditions, dry, rain, snow, ice, etc.. Mud was the only condition I never had them in (not counting dirt roads). Stock size, about $200 more than the ATP.
Cooper ATP: Have heard and read awesome things about this tire, but slightly concerned the little larger lug vs the A/T3 will cause it to not be as good of a tire in the wet, sloppy snow. Had a set of the Cooper ST's and wasn't that impressed in that type of snow. They would actually push at intersections when trying to turn. The A/T3's never did that. But I know there is a big difference in the tread pattern and tread size vs the ST model. Stock Size, about $200 cheaper vs the A/T3.
Slightly behind the two Coopers:
Pro Comp AT Sport: Very new tire, little reviews available and the few there are, haven't found any for snow conditions. 275/60/20, ever so slightly larger.... Any idea who make the PC tires? I have heard/ read possibly Cooper, but can't find a definitive answer. About the same price as the A/T3 if I remember correctly.
All three of these have a 55k or 60k mi tread warranty, which is a selling feature.
I would consider the BFG AT and the Toyo Open Country AT II if they were available in the right size. Have also considered the DuraTrac, but it may be a little more aggressive than I want/need. Other downside is the lack of a tread warranty. Have considered the Wrangler Adventure, but maybe this is also the lack of looking at the DuraTrac closer, I am not a big fan of GY tires.....
I have also considered going to an 18" rim for more tire choices, but after the cost of new rims (even oem take offs...) not sure this is really worth it. If I bought 18" rims, the Open Country AT II would be right there in he mix with the Coopers, and the BFG slightly behind due to no tread life warranty.
So if anyone has any insight on comparing these tires, all help is appreciated!!!
TY!!!
