PAB4's avatar
PAB4
Tires on Camplite 13 qbb
Have posted previously on my intention on purchasing a Camplite 13 qbb. I have a concern. I asked the dealer about the 13 in tires. He said to be honest with you these are not very good tires but should be safe enough for 2 years Huh? Has anyone experienced any issues. If I purchase the trailer I would like to upgrade to a better quality TT tire. Has anyone done this. Thanks!
  • The Camplite 13 QBB shows a single axle 3000 lb GVWR trailer which equates to 1500 lbs per tire as a minimum.
    Maxxis ST8008 has the best rep of all the ST tires at this time across the trailering forums and has a ST185/80-13 C load range at 1460 lbs per tire that will work.
    Maxxis also has a commercial grade U-168 Bravo LT5.50R13 in a 80 psi tire at 1480 lbs capacity and a same size 90 psi rated tire at 1610 lbs capacity.
    Check your wheels for proper width and pressure ratings for each tire. Both tires are very popular with the overall trailering crowd including RV folks.
    Or take a chance on the advertised much improved other ST tires with a nylon belt under the tread.
    ST tires are limited to 65 mph. A small 13" tire at that speed is rotating much higher rates than it bigger brothers. Keep the speed down.
    The single axle light weight trailer isn't as hard on tires as a heavy multi axle trailer. Many folks go with a 13 "P tire with good success, that has the proper load capacity.
  • Ask if he will upgrade the tires to something good like a Carlisle. Oh god here we go, now I started some chit.
  • Camplite , though still a young company, has a good reputation for customer satisfaction. If I were you, I'd speak to them directly about what the dealer's telling you. I'm pretty sure they'd like to be made aware that this may be an issue and might want to address it directly.
    Then of course there's the possibility that the dealer's just trying to upsell you some "better" tires....as if that ever happens!
  • Depending on how much wheel well clearance you have, When replacement time comes try to go with a 14 or better yet 15 in wheels and D rated tires. I went with 15 on my Bigfoot and it feels like the tow is more manageable
    That is another way of saying they are typical cheap, junk ST tires that most of the RV companies fit to campers just to help pad their bottom line profit.
    See my comments in the other thread you started if you care to hear my thoughts on it.
