Eyetattoo
May 22, 2013Explorer
Tire/wheel upgrade?
Just purchased my parents TT off them and noticed the tires are in need of replacement. The current set up is ST225/75R15 with a max load of 2540lbs. The trailer has a GVWR of 11,000lbs.
Should I stick with the 15s and ST tires or should I upgrade to 17s and a LT tire? If I go to the 17s what size tire should I go with to keep the same diameter? Thanks!
