trail-explorer wrote:
One day I will get a TItan Tank.
One thing I do know is the larger capacity means the fuel gallons used, and distance to empty numbers will no longer be valid.
I've read about the Titan tanks over on www.duramaxforum.com
You might get more feedback over there
My fuel gallons used is exactly the same as it was with the OEM tank. The distance to empty is off however, but can be reprogrammed by your GM dealer to allow for the increased fuel load. In my case I went from 26 gal to 52 gal and I can multiply by 2 in my head pretty easy.
