Baloney! Go to the Cummins Forums under Dodge trucks and ask. You can get a programmer such as an Edge and turn the fuel up to it. I has a 4 parameter readout that goes on the dash. You can program in TIT (Turbo inlet Temp) transmission Temp, water temp and the amount of suction. You may be able to turn it up 60 Horsepower and if you have to go to the shop, reset it to factory, pull the plug and remove the readout. I've run one for years and never had a problem in a Ford and a Chevy Duramax. Have my Chevy turned up 60 HP.
I know that Urea poured into an exhaust and super heated turns into ammonia which crystalizes in your lungs.
