Homeless_by_Cho's avatar
Dec 07, 2015
Garmin Montana 600T - How to delete "Active" files
I downloaded some tracks from my Garmin 60CSx onto the 600T. Those tracks included some "Active" files. I can't figure out how to delete them. Highlighting them and selecting "DELETE" doesn't do anything. Also, I downloaded a file called "Start" that I can not delete.
I don't download any more 60CSx files until I delete the "Active" track before downloading.
What other words besides "Start" and "Active" will get me in this jam? The Owners Manual doesn't address this issue.
Thanks,
LeRoy
  • Not a Garmin guru, but I have had my share of them. The active file may be the current track. When you turn the unit on it begins a track, even adding to the last track. This is automatic. There will always be an active track. Even if you USB connect it to a computer and delete the active track, the next time you turn it on it creates one again.
    The Start file is probably a waypoint, either user created or uploaded from the other device. Go into your waypoints list, find it and delete it.
    Hope that helps.
  • Wind River wrote:
    Google Garmin forums. You should be able to find an answer.
    I have done that extensively and have not found anything. I was hoping for some real ideas so I could work off of them.
    Thank you,
    LeRoy
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
