Lantley wrote:
1buda wrote:
I just blew air through out the entire water system, filled all the traps with antifreeze. We did get our first snow fall about 2". I plan on going out for Thanksgiving weekend. I think I should be good?
If you did not add antifreeze to your water lines you are taking a chance.
I also am planning to go out for Thanksgiving. I use a space heater when temps. dip below 32ยบ. I am in a milder climate than Pittsburgh but I am also taking a chance.
The only foolproof way to avoid problems is to use antifreeze.
Thanks for the advise. Tomorrow I'll run antifreeze through the lines.
