Jfet's avatar
Jfet
toad for truck camper? F250 4x4?
We just finished up a 11,000 mile loop of the USA in our homebuilt flatbed truck camper pulling a 17 foot sailboat. It performed flawlessly and I think we sailed in about 15 states plus the Atlantic and Gulf of Mexico.
The downside is the truck + camper and garage pod is a bit large for going up rocky steep mountain roads or really any sandy spot. I am also not comfortable at all driving in any ice or snow with the weight, height and 2wd. At 28 feet long it is a bit large for some of the cities we visited...we had to use Uber in New Orleans and rode the bus in Austin.
We are back in Washington state and want to do some winter and summer stuff here again...maybe even buy a bit of land for a home base. We still plan to go to Alaska and also Maine (didn't hit the NE on our first loop).
So...I was thinking we could get a toad for the RV and sometimes pull it instead of the sailboat. Or sometimes pull the sailboat with the toad and leave the RV at our home base. 4wd cars are around 25k new and I noticed I can get a 2017 4x4 F250 supercab (gas) with a 4000 pound payload and 12,500 pound hauling brand new for $35k. A 2wd regular cab is $30k new.
Trying to convince myself that a F250 4x4 is not too big for a toad. Opinions on that truck? It seems like it would also make a nice platform for a offroad camper if we get in the building mood again.
  • Superduties with a manual transfer case can be flat towed. I believe this also applies to manual transfer case Rams. You are probably looking at a 6k+ lb truck if it is a F250 or F350 gasser.
  • Yes right, sorry. Our truck is a 2006 Isuzu NRR flatbed with a max payload of around 11,000 pounds. We have been towing the sailboat (around 3200 pounds) for 11,000 miles without any real issues. We get about 9 to 11 mpg depending on wind and speed.
    Actually I am not sure you can even tow a F150 or F250 with wheels on the ground. I just found the manual and it says they can't be towed if they have electronic on the fly shifting, which almost all of the ones on the dealer lot do have (you would have to special order one with manual locking hubs).
    Here is a pic of our setup. I have a thread on here about the build too: Flatbed camper build
  • Jfet, you might get more informed suggestions if you spelled out exactly what your homebuilt flatbed truck camper consist of.
    Wayne
  • I can't really think of why you'd pull a F250 instead of a F150. It's quite a lot heavier (2000 lbs) and longer too from bed to front bumper. If you are talking popup, I think a F150 would be fine.
