laidbackExplorerDec 10, 2014toilet problemSo our less than year old cougar has a problem, the toilet doesn't flush. When you press the foot lever the water barely trickles out, not nearly enough to get the job done. Water pump is fine, bo...Show More
lj2654ExplorerDec 10, 2014are you sure the cutoff valve is turned all the way on if you have one?Or a line somewhere has come loose, but there would be a leak if that's the case!
Related ContentSwitching toiletsWanting a Bidet for my Thedford toilet.Dometic toilet valave problemDometic toilet problemAtwood water heater problem
