TnTRunaway
Nov 07, 2017Explorer
Step Up Toilet
I'm new to this site and I've looked around and haven't seen much on toilets here or I didn’t look very well or maybe it’s because not many have the problem I have w/ our RV Toilet. Not so much a problem as much as it is an inconvenience for me. And I'm probably the only one it inconveniences in my family because I'm the shortest and the only gal.:o
I have a 2007 Majestic 28A by Four Winds, and the toilet is a step up or a step above floor level, not sure how to describe and I don't know how to post pictures on here. The toilet is a step higher than the floor level and if you try to step up to use the toilet there's not enough floor space for your feet to do so. Since I'm the only one complaining about it and before I ask the hubby to look and see what's under it or to see if there is anything that can be done to remove the step and put in a regular size RV toilet, I wanted to ask for some input/advice. Does anyone else have this in their RV, if so did you change anything about it, and how did you do it? :h :@
