Farmboy666 wrote:
Make a step that slides back towards the toilet when not in use. Two pieces of wood screwed together at 90 degrees. The top one has a cut out of the toilet base so it can slide back or could be two separate pieces, one on each side for your feet to rest on when in use and the front piece is the height of the toilet step up. Slide it out to use and then back when not.
Presumably the vertical piece should also have a hole cut out for the heater vent. Otherwise, this sounds like a workable solution.
I was thinking of something rather similar, but hinged at the front rather than sliding. The hinged version would need some sort of a support cleat attached to the wall and maybe sink cabinet and on the whole sounds a little more complicated to put together.
