TnTRunaway wrote:
gotsmart, This just made me laugh out loud, seriously :B because you nailed exactly what has to be done to avoid tripping.. This is the exact configuration of my 28A and I actually do leave the door open and I've learned to keep the curtain closed in the bedroom or else there's a clear view in/out because I got tired of opening and closing that curtain every single time...
I don't have a curtain issue. I like a dark bedroom. I have the curtains always drawn on the 3 windows as well as Reflectix foil between the curtains and the glass, and a blackout cover on the bottom of the ceiling vent.
2 more tips.
1) My medicine cabinet does not go all the way to the ceiling. The top serves as a shelf to store 3 double-rolls of ones favorite toilet paper.
2) If your toilet paper holder is mounted on the wall similar to the below image then your knee is right under it when sitting on the toilet and it becomes kind of useless. Solution below the image.
If you don't have children then this works well. If you do, then YMMV.
Use the toilet paper holder as an aid for getting onto and off of the pedestal. Use one hand on the sink counter and the other hand on the toilet paper holder to steady yourself as you get on and off the pedestal.
BIG NOTE: The toilet paper holder is NOT a grab rail. It is not mounted in a way to support the full weight of a person. If your toilet paper holder is loose on the wall then using it to steady yourself IS NOT a good idea.
So, where to put the toilet paper? Get
one of these at Walmart.
Where to put it? Open the medicine cabinet door and hang it in the lower corner that is closest to the toilet. The door easily closes securely over it. I'd post a picture of mine, but Flickr is having issues at the moment.
The location of over-the-tank toilet paper holder on the cabinet works very well for me.
