So our less than year old cougar has a problem, the toilet doesn't flush. When you press the foot lever the water barely trickles out, not nearly enough to get the job done. Water pump is fine, bo...
Before you try the costly and tedious repairs, take a wire and probe the hole where the water is supposed to come out on the toilet rim. I replaced the valve with no improvement. The wire "repair" restored the full flow. Wished I'd have done that first.
