Has anyone replaced the flange that holds the two bolts that go thru the toilet to hold it down? I think it is called a closet flange Mine has all Phillips screws, but one of them has the square hol...
Are the screw heads big enough to use a Dremel with a grinding wheel or cutting disc to make 2 flats 180 deg appart to allow a small wrench or crescent wrench to turn them?
