Perrysburg_Dodg
May 19, 2014Explorer
At TMP we manufacture torque converters and steering columns. At min 51 in the video you see lugs being welded on the shell, then at 127 you see the Verson press stamping out covers. Note the size and thickness of the blanks we use. The last machine is a CNC grinder we use to grind the hubs for the TC. All but the Verson press are gone now to make way for the 235MM and 242MM converters.
For the most part the plant is kept clean, but there are areas that tend to be dirty. The screw machine dept for one and the press room. Both use a lot of coolant during manufacturing.
Don
Don
