GaryWT
Jun 22, 2016Explorer
SoundGuy wrote:SoundGuy wrote:
... I don't know of any foot flush toilet on which you'd lift the foot pedal to introduce water into the bowl :h ... rather, you'd depress it slightly to fill the bowl or completely to open the flush valve so the bowl contents would drop into the BW holding tank below.3oaks wrote:
There out there and quite common. All depends on make and model.
"Quite common"? :h With Dometic and Thetford being the two most common brands of toilets used in RVs in N America these days I've never seen one that introduces water into the bowl by pulling up on the foot pedal. Since you seem to believe this style of toilet is "quite common" it shouldn't be difficult at all for you to show us. :W
I have had 2 that you could lift the pedal to add water. The pedal was on the side of the bowl rather than the front. You put your foot under the pedal and lifted. It could get tiring if you were filling the bowl a few times to dump but at least you know the bowl would fill and not empty if you pushed a little too much. Not sure of the toilet brands but the trailers were a Canterbury and a North Trail that had them.
