jmcgsd wrote:
T_in_Michigan wrote:
That is why you have to be careful about watching Youtube videos, if you notice he mounted the jack turned all sideways, if he had mounted it correctly and face it forwards the holes would line up. The fact that he only uses 2 bolts instead of 3 is proof enough he has no idea what he is doing.
So are you saying the bolt pattern is not equidistant around the perimeter? If that's the case how do you move the motor to one side if you have to clear propane tanks or some other restriction? My propane tanks are mounted extremely lose to the jack.
IMPORTANT NOTICE: from manual…
If it is necessary to change the position of the powerhead relative to the post and flange (in order to
provide clearance between powerhead and LP gas bottle or LP gas cover, or more clearance between
the lift gate and the powerhead) loosen set screws and rotate head without lifting off coupling.
use the 3 set screws
part numbers...
14 608-0006 3 SET SCREW .313-18 X .50
30 636-0000 1 HEX KEY
Manual with exploded parts view…
click
