Bears_Den's avatar
Bears_Den
Tongue jack maintenance
My TT is 5 yrs old and I’ve never done anything to the electric jack. Is there any maintenance that should be done to it? It’s been working fine.
  • philh's avatar
    philh
    Explorer III
    afidel wrote:
    If it's an LCI unit they are a sealed unit and supposedly should not require any maintenance (IE they are disposable), other manufacturers call for partial disassembly and the application of a high melting point grease to wear surfaces.
    I got 6 months out of mine
  • There is a zerk on the Ultra-Fab. I do a couple pumps every spring, but it still makes awful grinding noises. Been this way for 4 years. Goes up and down, though.
  • I had a Barker that called out lubing something. I ignored that, probably over loaded it and basically abused it for 13 years.
    Despite all that, it worked flawlessly.
  • I don't recall any required maintenance for mine. It's about 14 years old now and still working great.
  • If it's an LCI unit they are a sealed unit and supposedly should not require any maintenance (IE they are disposable), other manufacturers call for partial disassembly and the application of a high melting point grease to wear surfaces.
