Doh! Yes, it's just three bolts, not 4. My bad.
SoundGuy wrote:
Atlee wrote:
Can't you just unbolt the current power jack and turn the whole assembly 90 degrees? Would save getting a new jack.
I bet if you think about it for a moment you'd realize a 3 bolt tongue jack can only be rotated in 120 degree increments. :W In this case the OP is replacing his tongue jack anyway so I'm suggesting he not only consider lift rating but also lower shaft diameter and whether the head itself can be rotated for the purpose of solving any potential tail gate clearance issue that many of us have with our own tongue jacks.
