wmoses
Oct 11, 2014Explorer
If the tongue weight is known (and I am not sure it is since it seems to vary depending on the length of the 4x4 beam) you cannot presume that the fore-aft split of the weight is anything at all. Hence you cannot guesstimate what the full weight of the trailer might be.
The only way is to go the scales at least once, and only then would you know what your weight split is, and can make adjustments after that. If the weights don't change much there is likely no need to ever weigh the trailer again.
