Huntindog wrote:
Try to imagine a tiny scale that would fit between the top of the ball and the coupler. What it would measure is the actual TW.... And that scale would read the same no matter what is done with WD.
Yeah...but it won't.
In addition to the weight of the trailer that is sitting on the ball, the bars (which are attached to the truck) are pulling the trailer A-frame down via the chains/L-brackets. Since this downward force is behind the ball and the ball cannot apply any significant moment arm, an upward force that is split between the ball and trailer axles must be applied to compensate.
- The part that goes onto the trailer axles is the reduction in hitch weight (around 200lb per the CAT scale on my current trailer).
- Since the bars are closer to the ball, most of this force goes onto the ball and is quite substantial. (On my trailer, the L-bracket is aprox 2ft behind the ball and the center of the axles about 18ft. If we run the calculations to keep the trailer in balance, the ball will see around 9 times (1800lb) more downward force to balance the moment arms.
So if we use your imaginary scale that fits between the ball and the coupler...with the 900lb hitch weight, the ball is seeing around 2700lb of downward force on my trailer (yes, WDH have some substantial forces within the system).
To find the hitch weight with WDH:
- If you were to cut the hitch at the square receiver (just ahead of both the ball and bar attachments), the upward force needed to stop the hitch head from dropping is the hitch weight. This is force that the truck suspension sees (in addition to the moment arm which is separate) and is really the point of finding the hitch weight, it is the combination of the weight on the ball minus upward lift from the bars. This actually is reduced depending on how stiff the bars are and how far you bend them when connected (again, around 200lb per the scales on my current trailer).
- Or go to the CAT scales and check the truck weight by itself and see how much it increases when you weigh it with the trailer and WDH connected.
