dcf wrote:
Yea, that's the total tongue weight the vehicle can handle. Not a question of a heavier hitch. It's related to overall wheelbase and suspension.
ok, that makes it harder, but doable. Just make sure to count propane, batteries (you may only need one?), etc. It all adds up... I usually say, the weights are guidelines, if you are over a few lbs, it will not break the moment you go over, but having a tongue weight scale will payoff when loading also, you can see exactly (as accurate as the scale is) how much each item adds or subtracts to tongue weight
